CrowPi2 FAQ
edited October 17 in Raspberry Pi & CrowPi
Hardware problem:
On-board Module Problem:
  1. How can I know all the information of CrowPi2 on-board modules?
  2. What to do if the fan makes noise?
Button & Keyboard & Mouse Problem:
  1. How to toggle the trackpad on/off.
  2. Why do the (+) and (-) keys only work with screen brightness?
  3. The Keyboard and/or Mouse does not work.
  4. How to pair when the keyboard and mouse do not match?
Power Problem:
  1. Is there an user guide available for the Power Bank that came with the Advanced and Deluxe Kit?
  2. What are the specifications of the Power Bank that came with the Advanced and Deluxe Kit?
  3. What are the internal dimensions of the storage tray for Power Bank?
  4. Power shuts off automatically after about 30 seconds during boot up.
  5. [HowTo] Powering the CrowPi2 using a Power Bank---Shared by Pearl
Warning Problem:
  1. A "Low Voltage Warning" indication when powering through the microUSB Power Port.
  2. Pop-up warning, "The software needs to run on CrowPi2, and turn the toggle switch to the A-side!"
Monitor Problem:
  1. How to enable Pixel Doubling for a high resolution monitor?
  2. LCD doesn’t work after updating(using command “sudo apt-get dist-upgrade” or "sudo rpi-update").
  3. "No Signal" error on the CrowPi2 screen
Accessories Problem:
  1. Why can't the SDA0 (BCM_GPIO-0) pin be used?
  2. Which Raspberry Pi model(s) are recommended for running the Crowpi2 software?
  3. How to solve the problem of fan noise?
Raspberry Pi Version Problem:
  1. Which Raspberry Pi version is recommended by CrowPi2 software?
Replacing:
  1. How to disassembly CrowPi2?
Software problem:
Image Problem:
  1. Where can I download the CrowPi2 latest image?
  2. How to update the Crowpi2 OS image?
  3. CrowPi2 64-bit Image
System Problem:
  1. No audio sound after a system upgrade (sudo apt full-upgrade).
  2. Can I run different OS on CrowPi2 (ex. Raspberry Pi OS, RetroPie, LibreELEC, Ubuntu, etc.)?
  3. How to expand the Raspberry Pi filesystem?
  4. How to backup the system SD card?
  5. To install the new Raspbain system, what configurations should be done?
  6. WiFi Problem
  7. CrowPi2 Automatically Shut-down
Crowpi2 Software Problem:
  1. How to disable the Crowpi2 software from autostart at bootup?
  2. How to quit the Crowpi2 software?
  3. How to install Letscode( .deb) on Crowpi2?
Scratch Problem:
  1. How to adjust the font size of the Scratch Desktop interface?
  2. Picture 11-24 is missed on the last page(98) of Scratch book.
Learning Course Problem:
  1. Where can I find the source code of all the learning lessons?
  2. Error of Python lesson “using the DHT11 sensor”.
  3. Error of Python lesson “making circuit using the bread board”.
Project Menu Problem:
  1. Where can I get the code of Project menu?
Photo problem:
  1. How to take a photograph by using Crowpi2
  • Hey,Can u tell me what exactly are the dimensions of the battery tray? What specifically is the largest battery/powerbank that will fit?
  • edited October 2021
    @Look4U
    The answer to your question is already stated in the FAQ #Power Problem 3.
  • Hi, I am having trouble booting up my crowpi2 raspberry pi laptop. It only goes to a terminal, and states: "Fatal Python error: init_fs_encoding: failed to get the Python codec for the filesystem encoding
    Python runtime state: core initialized
    ModuleNotFoundError: No module named 'encodings'
    Current thread 0xb6faa010 (most recent call first):
  • Well, its quite informational. I gained a lot of knowledge from it. But can you answer of the question: does blooket cost money? It would be a great favour to me.
    The answer already provided in the link from your question.
    No. It's free.
  • @Pearl said:
    @Look4U
    Although I am sure you have moved on, the answer provided in the FAQ isn't quite right to answer your question.
    https://forum.elecrow.com/discussion/69/what-are-the-internal-dimensions-of-the-storage-tray-for-power-bank#latest
    "The internal dimensions of the storage tray are
    147 x 78 x 9.5 mm
    5.79 x 3.07 x 0.37 inches"
    The tray on my unit includes 6 plastic supports / spacers inside the tray as well as a proud rubber button on the front. As a result, without physical modification, the tray will not accept power banks up to the listed dimensions.
    My tray will only accept power banks up to.
    146.5 x 69.5 x 9.5 mm
