Pop-up warning, "The software needs to run on CrowPi2, and turn the toggle switch to the A-side!"
in Programming
There is a slide switch next to the fan that controls the connection of all the onboard sensors on CrowPi2. When the Crowpi2 software starts, the Switch position must be set on the A-side CONNECT SENSOR (Left).
Even after updating the OS and restarting, the Crowpi2 program still gives this warning with the switch being to either side. Everything else continues to work, just the program will not open.
