How to solve the problem of fan noise?
The problem may be caused by loosen fan, you can directly press the fan down to fix the fan tightly.
In addition, if you want to permanently fix the fan, there is a double-sided tape on the back of the fan, you only need to tear it off, and then stick it to the fan port, so that there will be no noise caused by the loose fan in the future.
