How to disable the Crowpi2 software from autostart at bootup?
edited January 2025 in Raspberry Pi & CrowPi
Remove the 1.desktop file from the ~/.config/autostart folder.
  1. Press Ctrl+Alt+T, a new Terminal window appears.
  2. At the command prompt, type mv ~/.config/autostart/1.desktop ~/ and press Enter
pi@Crowpi2-:~ $ mv ~/.config/autostart/1.desktop ~/
Note:
  1. If you change your mind later, just move the file back into the ~/.config/autostart folder.
  2. You can also launch the software manually from the Taskbar, click menu Education CrowPi2
Update: The file folder error has been corrected.
  • Had no success with the posted link. Went to the autostart folder and found CrowPanel. Should I substitute this file for 1.desktop?
  • Hello @gilwood ,
    You only need to move the 1.desktop file out of the  home/pi/.config/autostart folder.
    There's a mistake in the command posted before. You should run mv home/pi/.config/autostart/1.desktop ~/ or mv ~/.config/autostart/1.desktop ~/ in the terminal.
    After that the 1.desktop file will be moved to /home/pi directory. Then reboot the CrowPi2, the software will not automatically start any more.
    PS. You can click "menu"→"Education"→"CrowPi2" to start the software.
  • To disable the Crowpi2 software from autostarting at bootup, you can modify the startup settings in the Raspberry Pi's system configuration or remove the autostart entry from the system's startup scripts.
