CrowPi2 FAQs
Hardware problem:
On-board Module Problem:
Button & Keyboard & Mouse Problem:
- How to toggle the trackpad on/off.
 - Why do the (+) and (-) keys only work with screen brightness?
 - The Keyboard and/or Mouse does not work.
 - How to pair when the keyboard and mouse do not match?
Power Problem:
- Is there an user guide available for the Power Bank that came with the Advanced and Deluxe Kit?
 - What are the specifications of the Power Bank that came with the Advanced and Deluxe Kit?
 - What are the internal dimensions of the storage tray for Power Bank?
 - Power shuts off automatically after about 30 seconds during boot up.
 - [HowTo] Powering the CrowPi2 using a Power Bank---Shared by Pearl
Warning Problem:
- A "Low Voltage Warning" indication when powering through the microUSB Power Port.
 - Pop-up warning, "The software needs to run on CrowPi2, and turn the toggle switch to the A-side!"
Monitor Problem:
- How to enable Pixel Doubling for a high resolution monitor?
 - LCD doesn’t work after updating(using command “sudo apt-get dist-upgrade” or "sudo rpi-update").
 - "No Signal" error on the CrowPi2 screen
Accessories Problem:
- Why can't the SDA0 (BCM_GPIO-0) pin be used?
 - Which Raspberry Pi model(s) are recommended for running the Crowpi2 software?
 - How to solve the problem of fan noise?
Raspberry Pi Version Problem:
Replacing:
Software problem:
Image Problem:
- Where can I download the CrowPi2 latest image?
 - How to update the Crowpi2 OS image?
 - CrowPi2 64-bit Image
System Problem:
- No audio sound after a system upgrade (sudo apt full-upgrade).
 - Can I run different OS on CrowPi2 (ex. Raspberry Pi OS, RetroPie, LibreELEC, Ubuntu, etc.)?
 - How to expand the Raspberry Pi filesystem?
 - How to backup the system SD card?
 - To install the new Raspbain system, what configurations should be done?
 - WiFi Problem
 - CrowPi2 Automatically Shut-down
 - Unable to open the login interface/Unable to log in, what should I do?
Crowpi2 Software Problem:
- How to disable the Crowpi2 software from autostart at bootup?
 - How to quit the Crowpi2 software?
 - How to install Letscode( .deb) on Crowpi2?
Scratch Problem:
- How to adjust the font size of the Scratch Desktop interface?
 - Picture 11-24 is missed on the last page(98) of Scratch book.
Learning Course Problem:
- Where can I find the source code of all the learning lessons?
 - Error of Python lesson “using the DHT11 sensor”.
 - Error of Python lesson “making circuit using the bread board”.
Project Menu Problem:
Photo problem:
Hey,Can u tell me what exactly are the dimensions of the battery tray? What specifically is the largest battery/powerbank that will fit?
@Look4U
The answer to your question is already stated in the FAQ #Power Problem 3.
Hi, I am having trouble booting up my crowpi2 raspberry pi laptop. It only goes to a terminal, and states: "Fatal Python error: init_fs_encoding: failed to get the Python codec for the filesystem encoding
Python runtime state: core initialized
ModuleNotFoundError: No module named 'encodings'
Current thread 0xb6faa010 (most recent call first):
Well, its quite informational. I gained a lot of knowledge from it. But can you answer of the question: does blooket cost money? It would be a great favour to me.
The answer already provided in the link from your question.
No. It's free.
Although I am sure you have moved on, the answer provided in the FAQ isn't quite right to answer your question.
https://forum.elecrow.com/discussion/69/what-are-the-internal-dimensions-of-the-storage-tray-for-power-bank#latest
"The internal dimensions of the storage tray are
147 x 78 x 9.5 mm
5.79 x 3.07 x 0.37 inches"
The tray on my unit includes 6 plastic supports / spacers inside the tray as well as a proud rubber button on the front. As a result, without physical modification, the tray will not accept power banks up to the listed dimensions.
My tray will only accept power banks up to.
146.5 x 69.5 x 9.5 mm
New to CrowPi2.
I need to apply updates. Whenever I do I get an error which is truncated so I can't read it in full.
Is there a log file so I can see what the error is?
Is there a copy command for a dialog window so I can paste it elsewhere.
Any advice on how to complete the updates would be appreciated. I have tried quite a few times and each has failed. I was hoping repeating the updates would eventually work just leaving the failing one in the queue. No such luck.
I have an image of the problem but it has to be hosted somewhere as you have to specify a URL. Can someone please let me know of a suitable service/server I can use? Its A long time since I had to do anything like this.
You can upload an image. Thats great!!
I have the same problem
