Compilation and runtime problems ..
edited January 2024 in ESP32 & Lora
Hello all,
trying to get some basic code compiled on a Wizee-ESP32 WZ8048C050. Unfortunately the example provided here https://www.elecrow.com/wiki/index.php?title=File:LvglWidgets-5.0-helloworld.zip doesn't compile. It seems that the GFX Library for Arduino needs to be a much older Version like 1.3.0.
After compiling successfully there's now a runtime error stating:
-> E (19) lcd_panel.rgb: esp_lcd_new_rgb_panel(151): no mem for frame buffer
-> ESP_ERROR_CHECK failed: esp_err_t 0x101 (ESP_ERR_NO_MEM) at 0x4037abf4
-> file: "z:\nextcloud\arduino\libraries\GFX_Library_for_Arduino\src\databus\Arduino_ESP32RGBPanel.cpp" line 118
-> func: uint16_t* Arduino_ESP32RGBPanel::getFrameBuffer(int16_t, int16_t)
-> expression: esp_lcd_new_rgb_panel(_panel_config, &_panel_handle)
and the display is caught in a reboot loop. Is there any suggestions or a fix for this?
Arduino IDE v2.2.1
GFX Library for Arduino v1.4.1
selected Board: ESP32S3 Dev Module
