About CrowView, the screen only displays for a few seconds before losing the signal
Question:
About CrowView, I am experiencing an issue when connecting the product to the screen via USB cable. Specifically, the screen only displays for a few seconds before losing the signal, and the connection remains unstable despite trying multiple USB cables. They also face an issue where changing the orientation of the cable sometimes causes the signal to appear or disappear.
Answer:
The problem persists even after trying several cables. It's highly likely that the device isn't being provided sufficient power. Please try connecting two USB cables to the Crowview device—one for power and one for video signal transmission.
Also, connecting both Type-C ports to the same laptop simultaneously might not produce noticeable results. We recommend using a 5V/2A power adapter for one typeC port of the Crowview device (a power adapter is included in our product packaging).
Furthermore, is the data cable you're using (the one for video signal transmission) USB4, Thunderbolt 4, or Thunderbolt 5? Does this cable support full video functionality? Alternatively, please use the USB cable included in our product packaging.
  • I am having the same problem with the CrowView Note 15.6 but I am not using the BridgeBoard and not using USB-C.
    I connect the Raspberry PI USB to CrowView USB (1). (left side, master device)
    I connect the Raspberry Pi HDMI to CrowView Note HDMI
    CrowView Note is plugged into its own power supply
    Raspberry Pi is plugged into its own power supply.
    CrowView Note says "no signal detected" and goes to sleep mode.
    None of the Fn keys work. Fn - F7 does not bring up the OSD display.
    Why does the CrowView not detect the HDMI signal?
  • edited April 17
    The problem appears to be my HDMI to HDMI mini adapter. First, I plugged in a MacBook Air using USB-C and this worked. Then I tried the Rasbperry Pi Desktop which has a large HDMI port and this works with the CrowView using the USB-USB. So I need a proper HDMI mini-HDMI mini cable. Any suggestions?
