RC101S 10.1
Hi, I purchased this on September 2022, and it has been working OK. I needed to unplug it and move it, but when plugging back in it is lighting up but not showing the normal boot screen with the elecrow logo - not even the "No Signal" message when nothing is connected.
What can I do to diagnose this issue?
Cheers
Gary
  • @Gary Hi, please test whether the screen can work normally under the original connection and working environment.
  • Hi,
    I did this as I only unplugged it to move it, and then re-connected it (so it was all as before).
    I've also tried a separate power connector (not using the connected RPI4) and it lights up so you can see it has power, however it never gets to the Elecrow logo.
    Cheers
    Gary
  • edited December 2022
    @Gary Could you please try to connect it to a laptop/PC as a second screen and see if there will display something? If this will not help, please contact with order@elecrow.com for costumer service.
  • I've connected it as a second display to a windows 10 laptop, and the laptop sees the display (as it will allow me to expand the desktop to it).
    However there is no content being displayed (although the mouse will move across to the RC101S display as though it is on).
    As there is no onscreen display I cannot use the rocker on the RC101S to change the brightness.
    Is this a fault and now needs to be progressed via customer services?
    Cheers
    Gary
  • edited February 2023
    Hi, I really like the monitor for my RaspberryPI4, but unfortunately there is a small problem:
    I am using it with Ubuntu64 and it only works with deprecated "fake" kms driver: vc4-fkms-v3d
    When the system switches to kms driver (vc4-kms-v3d) the picture does not appear anymore.
    dmesg output "vc4-drm gpu: [drm] Cannot find any crtc or sizes" indicates that it failed to parse monitor EDID.
    I would set up the custom hdmi mode, but for that I need to know display's parameters:
    hdmi_timings=<h_active_pixels> <h_sync_polarity> <h_front_porch> <h_sync_pulse> <h_back_porch> <v_active_lines> <v_sync_polarity> <v_front_porch> <v_sync_pulse> <v_back_porch> <v_sync_offset_a> <v_sync_offset_b> <pixel_rep> <frame_rate> <interlaced> <pixel_freq> <aspect_ratio>
    Some of the parameters I know (i.e. h_active_pixels, frame_rate, pixel_freq, aspect_ratio) but some I do not:
    <h_sync_polarity> = invert hsync polarity
    <h_front_porch>  = horizontal forward padding from DE active edge
    <h_sync_pulse>  = hsync pulse width in pixel clocks
    <h_back_porch>  = vertical back padding from DE active edge
    <v_active_lines> = vertical pixels height (lines)
    <v_sync_polarity> = invert vsync polarity
    <v_front_porch>  = vertical forward padding from DE active edge
    <v_sync_pulse>  = vsync pulse width in pixel clocks
    <v_back_porch>  = vertical back padding from DE active edge
    Could you help me with those? Or just provide data sheet on the panel.
    Thank you!
  • Note that values taken from EDID info (which is available when fkms is used) do not work:
    hdmi_timings based on EDID:
    hdmi_force_hotplug=1
    hdmi_group=2
    hdmi_mode=87
    hdmi_force_mode=1
    #hdmi_cvt=1920 1080 60 3 0 0 0
    hdmi_timings=1920 0 88 44 148 1080 0 4 5 36 0 0 0 60 0 124416000 3
    EDID:
    edid-decode (hex):
    00 ff ff ff ff ff ff 00 53 04 00 00 01 01 01 01
    00 3a 01 03 80 00 00 78 ea 53 a5 a7 56 52 9c 26
    11 50 54 21 08 00 81 00 81 40 81 80 95 00 b3 00
    8b c0 a9 40 01 01 02 3a 80 18 71 38 2d 40 58 2c
    45 00 00 00 00 00 00 1e 7f 21 56 aa 51 00 1e 30
    46 8f 33 00 00 00 00 00 00 1e 00 00 00 fd 00 38
    3e 1e 53 19 00 0a 20 20 20 20 20 20 00 00 00 fc
    00 48 44 4d 49 0a 20 20 20 20 20 20 20 20 01 bd
    02 03 1d f1 4a 90 04 03 02 1f 13 12 11 05 14 23
    09 7f 07 83 01 00 00 65 03 0c 00 10 00 02 3a 80
    18 71 38 2d 40 58 2c 45 00 00 00 00 00 00 1e 01
    1d 00 72 51 d0 1e 20 6e 28 55 00 00 00 00 00 00
    1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 00 00 00
    00 00 18 01 1d 80 18 71 1c 16 20 58 2c 25 00 00
    00 00 00 00 9e 00 00 00 00 00 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30
    Block 0, Base EDID:
      EDID Structure Version & Revision: 1.3
      Vendor & Product Identification:
        Manufacturer: TXD
        Model: 0
        Serial Number: 16843009
        Made in: 2048
      Basic Display Parameters & Features:
        Digital display
        Image size is variable
        Gamma: 2.20
        DPMS levels: Standby Suspend Off
        RGB color display
        First detailed timing is the preferred timing
      Color Characteristics:
        Red  : 0.6533, 0.3369
        Green: 0.3203, 0.6123
        Blue : 0.1503, 0.0683
        White: 0.3134, 0.3291
      Established Timings I & II:
        DMT 0x04:   640x480    59.940476 Hz   4:3     31.469 kHz     25.175000 MHz
        DMT 0x09:   800x600    60.316541 Hz   4:3     37.879 kHz     40.000000 MHz
        DMT 0x10:  1024x768    60.003840 Hz   4:3     48.363 kHz     65.000000 MHz
      Standard Timings:
        DMT 0x1c:  1280x800    59.810326 Hz  16:10    49.702 kHz     83.500000 MHz
        DMT 0x20:  1280x960    60.000000 Hz   4:3     60.000 kHz    108.000000 MHz
        DMT 0x23:  1280x1024   60.019740 Hz   5:4     63.981 kHz    108.000000 MHz
        DMT 0x2f:  1440x900    59.887445 Hz  16:10    55.935 kHz    106.500000 MHz
        DMT 0x3a:  1680x1050   59.954250 Hz  16:10    65.290 kHz    146.250000 MHz
        GTF     :  1360x765    60.000341 Hz  16:9     47.520 kHz     84.396000 MHz
        DMT 0x33:  1600x1200   60.000000 Hz   4:3     75.000 kHz    162.000000 MHz
      Detailed Timing Descriptors:
        DTD 1:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
                     Hfront   88 Hsync  44 Hback  148 Hpol P
                     Vfront    4 Vsync   5 Vback   36 Vpol P
        DTD 2:  1366x768    59.964364 Hz 683:384   47.852 kHz     85.750000 MHz
                     Hfront   70 Hsync 143 Hback  213 Hpol P
                     Vfront    3 Vsync   3 Vback   24 Vpol P
        Display Range Limits:
          Monitor ranges (GTF): 56-62 Hz V, 30-83 kHz H, max dotclock 250 MHz
        Display Product Name: 'HDMI'
      Extension blocks: 1
    Checksum: 0xbd
    Block 1, CTA-861 Extension Block:
      Revision: 3
      Underscans IT Video Formats by default
      Basic audio support
      Supports YCbCr 4:4:4
      Supports YCbCr 4:2:2
      Native detailed modes: 1
      Video Data Block:
        VIC  16:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz (native)
        VIC   4:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz
        VIC   3:   720x480    59.940060 Hz  16:9     31.469 kHz     27.000000 MHz
        VIC   2:   720x480    59.940060 Hz   4:3     31.469 kHz     27.000000 MHz
        VIC  31:  1920x1080   50.000000 Hz  16:9     56.250 kHz    148.500000 MHz
        VIC  19:  1280x720    50.000000 Hz  16:9     37.500 kHz     74.250000 MHz
        VIC  18:   720x576    50.000000 Hz  16:9     31.250 kHz     27.000000 MHz
        VIC  17:   720x576    50.000000 Hz   4:3     31.250 kHz     27.000000 MHz
        VIC   5:  1920x1080i  60.000000 Hz  16:9     33.750 kHz     74.250000 MHz
        VIC  20:  1920x1080i  50.000000 Hz  16:9     28.125 kHz     74.250000 MHz
      Audio Data Block:
        Linear PCM:
          Max channels: 2
          Supported sample rates (kHz): 192 176.4 96 88.2 48 44.1 32
          Supported sample sizes (bits): 24 20 16
      Speaker Allocation Data Block:
        FL/FR - Front Left/Right
      Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
        Source physical address: 1.0.0.0
        DTD 3:  1920x1080   60.000000 Hz  16:9     67.500 kHz    148.500000 MHz
        DTD 4:  1280x720    60.000000 Hz  16:9     45.000 kHz     74.250000 MHz
                     Hfront  110 Hsync  40 Hback  220 Hpol P
                     Vfront    5 Vsync   5 Vback   20 Vpol P
        DTD 5:   720x480    59.940060 Hz   3:2     31.469 kHz     27.000000 MHz
                     Hfront   16 Hsync  62 Hback   60 Hpol N
                     Vfront    9 Vsync   6 Vback   30 Vpol N
        DTD 6:  1920x1080i  60.000000 Hz  16:9     33.750 kHz     74.250000 MHz
                     Vfront    2 Vsync   5 Vback   15 Vpol P Vfront +0.5 Odd Field
                     Vfront    2 Vsync   5 Vback   15 Vpol P Vback  +0.5 Even Field
    Checksum: 0x30
  • @GeorgeY Hi George, please try
    hdmi_timings=1024 1 50 18 50 600 1 15 3 15 0 0 0 60 0 40000000 3
