ESP32 Touchscreen Monitor 2.8 Inch TFT compile issues in Arduino IDE
Using Arduino IDE 2.2.1 and recently purchased Elecrow ESP32 2.8 touch screen module.
I have followed all instructions in the Elecrow tutorial.
Step 6 of the Elecrow tutorial specifies select "Board: ESP32S3 Dev Module" in the Arduino IDE.
I select "ESP32S3 Dev Module" and configure compiler settings as specified in the tutorial.
The Arduino IDE compiles ok but fails at upload with following error messages:
"/Users/dveach/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool" --chip esp32s3 --port "/dev/cu.usbserial-3130" --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size 4MB 0x0 "/private/var/folders/rw/4_9vxsh56sjfzl1sxr875yz80000gn/T/arduino/sketches/248A0F840B1C087844B1E31ACA36FFA2/TFT-LCD-2.8.ino.bootloader.bin" 0x8000 "/private/var/folders/rw/4_9vxsh56sjfzl1sxr875yz80000gn/T/arduino/sketches/248A0F840B1C087844B1E31ACA36FFA2/TFT-LCD-2.8.ino.partitions.bin" 0xe000 "/Users/dveach/Library/Arduino15/packages/esp32/hardware/esp32/2.0.13/tools/partitions/boot_app0.bin" 0x10000 "/private/var/folders/rw/4_9vxsh56sjfzl1sxr875yz80000gn/T/arduino/sketches/248A0F840B1C087844B1E31ACA36FFA2/TFT-LCD-2.8.ino.bin"
esptool.py v4.5.1
Serial port /dev/cu.usbserial-3130
Connecting.....
A fatal error occurred: This chip is ESP32 not ESP32-S3. Wrong --chip argument?
Failed uploading: uploading error: exit status 2
Note: I also tried using the "ESP32 Dev Module" board setting but it will not upload either. It fails in the upload with the following error messages:
"/Users/dveach/Library/Arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool" --chip esp32 --port "/dev/cu.usbserial-3130" --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size 4MB 0x1000 "/private/var/folders/rw/4_9vxsh56sjfzl1sxr875yz80000gn/T/arduino/sketches/248A0F840B1C087844B1E31ACA36FFA2/TFT-LCD-2.8.ino.bootloader.bin" 0x8000 "/private/var/folders/rw/4_9vxsh56sjfzl1sxr875yz80000gn/T/arduino/sketches/248A0F840B1C087844B1E31ACA36FFA2/TFT-LCD-2.8.ino.partitions.bin" 0xe000 "/Users/dveach/Library/Arduino15/packages/esp32/hardware/esp32/2.0.13/tools/partitions/boot_app0.bin" 0x10000 "/private/var/folders/rw/4_9vxsh56sjfzl1sxr875yz80000gn/T/arduino/sketches/248A0F840B1C087844B1E31ACA36FFA2/TFT-LCD-2.8.ino.bin"
esptool.py v4.5.1
Connecting....
Chip is ESP32-D0WDQ6 (revision v1.0)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: b4:8a:0a:ae:3f:28
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
A fatal error occurred: Unable to verify flash chip connection (Serial data stream stopped: Possible serial noise or corruption.).
