Setting up raspberry pi with Elecrow 10.1 Touch screen
Hi, I installed raspbian into raspi 4gb 4b module. and then I connected it into 10.1 touch screen. It splashed for few seconds and it was not detecting the screen. I connected the raspi to 17inch monitor and it was working fine.
I followed the steps mentioned bellow. But it still does not detect the 10.1 touch screen. I tried with several raspberry pis, several micro sd cards and several touch screens of same elecrow 10.1 screens. What am I missing here?
Step 1: Open terminal and Download the driver on RPI
Run:
git clone https://github.com/Elecrow-keen/Elecrow-LCD101.git
Step 2: Install driver
Run:
CD Elecrow-LCD101
sudo chmod +x Elecrow-LCD101
sudo ./Elecrow-LCD101
  • Hi, you can troubleshoot in the following ways:
    1. Check in the config file if the resolution matches your screen.
    2. Check if the HDMI cable you are using is damaged.
    3. Connect your 10.1-inch screen to the computer to see if it can display. If it doesn't display when connected to the computer, your screen may be broken.
