TFT_eSPI Settings for User_Setup - ESP32-S3 RGB 5
2»
  • I have a new ESP32S3 3.5" Terminal board and cannot get anything to display on the screen. The screen goes white, and the sketch is working because I am getting serial.println() messages in the serial monitor, but nothing on the screen. I am not using, nor do I want to use Squareline Studio to keep things simple.
    Wrote a simple sketch using the TFT_eSPI library to work with the 3.5" (non-terminal) board and that works just fine, however I cannot get the 3.5" Terminal board to display anything.
    I suspect that the TFT_eSPI user_setup settings I"m using for the 3.5" terminal board are not correct. Below is what I am using. Can someone confirm these settings? Thanks!!
    #define ILI9488_DRIVER
    #define TFT_PARALLEL_16_BIT
    #define TFT_WIDTH 480
    #define TFT_HEIGHT 320
    #define TFT_MISO 41
    #define TFT_MOSI 2
    #define TFT_SCLK 42
    #define TFT_CS  -1 // Chip select control pin
    #define TFT_DC  2 // Data Command control pin
    #define TFT_RST -1 // Reset pin (could connect to Arduino RESET pin)
    #define TFT_BL  46 // LED back-light
    #define TOUCH_CS 33 // Chip select pin (T_CS) of touch screen
    #define TFT_BUZZER 20
    #define TFT_WR  18 // Write strobe control pin - must use a pin in the range 0-31
    #define TFT_RD  48 // Read strobe control pin
    #define TFT_D0  47
    #define TFT_D1  21
    #define TFT_D2  14
    #define TFT_D3  13
    #define TFT_D4  12
    #define TFT_D5  11
    #define TFT_D6  10
    #define TFT_D7  9
    #define TFT_D8 3
    #define TFT_D9  8
    #define TFT_D10 16
    #define TFT_D11 15
    #define TFT_D12 7
    #define TFT_D13 6
    #define TFT_D14 5
    #define TFT_D15 4
