What is the difference between CrowPanel Advance 7.0-HMI ESP32 AI Display v1.0 and v1.2
13»
  • edited May 7
    @MicroGuy said:
    So far, I'm having difficulty also. What used to work on the older board, no longer works. I'm not sure what all has changed.
    I'll keep looking, I have much to sort through. But as of now, even the backlight doesn't work. The most basic serial program does not work (set up serial, send text, that's it). The display unit simply resets over and over. (I know the BL function has changed, so I can work on that, but I have no idea what's wrong with the serial, it's a VERY basic program)
    I will look at the provided code, and see if I can make some changes to get things working again. There is much to digest.
    One BIG problem is that the examples use OLD libraries. And the "Platformio" example, is really a "Squareline" example.
    HI, MicroGuy,
    I'm sorry. If your program is to be used on different hardware versions, you will need to modify it. You can refer to the tutorials and sample codes on our wiki and github.
    Warm regards,
