HMI Advance esp32-s3 series products common FAQs
HMI Advance esp32-s3 series products including: screen sizes from 2.4 inch to 7 inch
- why is the display of CrowPanel Advance HMI ESP32 flicker?
https://forum.elecrow.com/discussion/27350/why-is-the-display-of-crowpanel-advance-hmi-esp32-flicker#latest
2.Errors or black screen after uploading sample programs in the HMI advance esp32-s3 series
https://forum.elecrow.com/discussion/28091/errors-or-black-screen-after-uploading-sample-programs-in-the-hmi-advance-esp32-s3-series#latest
3.Can the DIS02050A display show the remaining battery capacity on the screen?
https://forum.elecrow.com/discussion/28204/can-the-dis02050a-display-show-the-remaining-battery-capacity-on-the-screen/p1?new=1
Hi, can you update the replacement ESP32S3_120M for use with the latest ESP32 V3.3.7 code please.
HI, Acuario,
I'm sorry, we don't have that plan at the moment. However, I will forward your feedback to the relevant department for future analysis and improvement.
I apologize for any inconvenience this may have caused.
Warm regards,
ok, so can you at least make public the changes in the code to enable the high speed psram - maybe on GitHub?? As you have only published the compiled code it is impossible to know what has changed. With knowledge of the changes it would permit developers to modify and compile the later code bases.
At the moment you are making your display more obsolete with every new release of the ESP32 code.
HI, Acuario,
Sorry, we need some time to analyze this issue. We will get back to you as soon as possible. Please wait for a while.
We apologize for any inconvenience this may cause.
Thanks!
Warm regards,
HI, Acuario,
We haven't released any tutorials or methods on this topic before, so you may need to wait a little longer. We need to discuss this further internally. I will get back to you as soon as I have the results.
I apologize for any inconvenience this may cause.
Thanks!
Warm regards,
