Can the nvme and Lorawan co exist on new pi terminal
Can you get an adapter which allows the Lora module and the nvme ssd to work together on the new pi terminal touch screen
Yes, you can find adapters that enable the LoRa module and NVMe SSD to work together with the new Pi terminal touch screen. Check compatibility and power requirements for optimal performance.
ok i have looked every where and i cannot find a pcie board that you can mount a nvme and lorA on for the new pi terminal i have the terminal fully populated but i would like to add an nvme to it can you point me in the right direction
another question when i first started my pi terminal up and logged in via ssh i get a load of erros with a python script trying to find a non existent elcrow direcotry , plus there was no node red shortcut on my desktop ,, ok any ideas where the python script are bbing run from
Hi, please provide a screenshot of the error message. You can find node red by clicking on the Raspberry PI icon in the top left corner of your desktop.
i also found that i have a usb0 net work on 192.168.10.2 ,not one of mine plus the routing table points to this as the default gateway so i cant even update through the net it without temporary editing resolve.conf for dns resolution and changeling default routes .
think ill just whip out a new sdcard and spin up my own build
Yes, you can get an adapter like a PCIe splitter or HAT that supports both a LoRa module and an NVMe SSD, but compatibility depends on the Raspberry Pi model and available PCIe lanes. Make sure the power and data requirements for both devices are supported.
You can run an NVMe SSD and LoRa module on the Pi Terminal using a PCIe splitter or separate HATs if the Pi supports the lanes and power. Python errors and missing Node-RED shortcut come from the Elecrow OS; Node-RED is in the Raspberry Pi menu. The
usb0network issue is from preconfigured virtual networks. Easiest solution is a fresh SD card with your own Pi OS build.
