Touch not working on 7" 1024x600 Display
Hi,
I purchased the 7" display from Elecrow and I am having issues getting the touch functionality to work. I previously had the 5" elecrow display running on the same Raspberry Pi (it's an industrial version called RevPi) and the touch was working fine. Since this is an industrial I cannot reimage it with a stock version of the image and used the manual setup method for the display. Is there something additional that I need to add in order to get the touch functionality to work?
Thanks!
Thanks!
I can not get the 7" touch screen working on a pi 4 regardless of what i add to config.txt or witch usb cable i use.
I have also tried 64 bit and 32 bit o.s.
@Tonyd1
I think the Touchscreen interface communicate over I2C, so make sure the I2C interface on your Pi4 is enabled.
