CrowPi 3 - Am I able to add my own AI?
I have my own local AI that I have been using for programming, and I would like to know if I can add this local AI to the Crow Pi 3? If not, can I add my own API? Why does the API key addition box in ThinkNode only accept 20 characters? Most APIs are about 32 characters long, and some are as long as 80 characters.
Dear Customer/Sender,
Best regards,
CrowPi 3 can run your own local AI since it is a Raspberry Pi, as long as the model works within the Pi’s hardware limits.
ThinkNode does not support custom local AI models and has a fixed API key length, which is why longer keys are not accepted. To use your own AI or full API keys, you need to integrate it directly on the OS level instead of through ThinkNode.
