HMI display with regular monitor
Is it possible to mirror the display image to a regular monitor? Perhaps using an external UART-to-VGA converter or some similar solution. Do you have a solution for this, and is it possible? I'm using CrowPanel ESP32 HMI 5.0-inch Display.
My idea is to connect a regular monitor to an HMI display's Type-C connector (UART). Perhaps this connection is an external UART-to-VGA converter. Then the HMI display draws the image internally (using the LVGL library) and simultaneously mirrors it to the UART. I don't think any performance gains are possible here, but I'm interested in the possibility of doing so.
Dear Customer/Sender,
We have seen your messages, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
Best regards,
Quote
Dear Nick,
I am sorry , to mirror the display image to a regular monitor is not supported by this device .
Thanks!
Best regards,
