HMI display with regular monitor
Is it possible to mirror the display image to a regular monitor? Perhaps using an external UART-to-VGA converter or some similar solution. Do you have a solution for this, and is it possible? I'm using CrowPanel ESP32 HMI 5.0-inch Display.
My idea is to connect a regular monitor to an HMI display's Type-C connector (UART). Perhaps this connection is an external UART-to-VGA converter. Then the HMI display draws the image internally (using the LVGL library) and simultaneously mirrors it to the UART. I don't think any performance gains are possible here, but I'm interested in the possibility of doing so.
  • Dear Customer/Sender,
    We have seen your messages, and our technical support team is reviewing the details. Please allow us some time to look into the matter. We will get back to you as soon as possible with an update.
    In the meantime, pls check if you have provided the following information. if not, pls send to us, so that we can fix your problems faster.
    pl tell us exactly which of our products you are using. We need to know the SKU No. . Or Please provide the purchase link for the product. so that we can continue to analyze the issue
    Also, please provide the order number, product purchase link(if applicable), along with the name of the retailer, store, platform, or website where you purchased the product?
    Quote
  • Dear Nick,
    I am sorry , to mirror the display image to a regular monitor is not supported by this device .
  • I got it, thank You for your investigation into my issue.
