Datasheets of parts in Elecrow Parts Library
I am looking at the Elecrow Parts Library list for parts selection for PCBA, but some datasheets are out of links.
Where can I get the datasheets for the following four parts?
- Power Supply 5011533A LD1117-3v3
- MOSFET 4022023A CJ2305
- MOSFET 4030523A Si2305
- Diode 4011554B SS54B
Hello @hymd ,
The Elecrow Parts Library list is closed. Could you send the link you visited for us to check?
The list I am looking at is an Excel sheet for Elecrow PCBA.
For example, for regulators, the cells are as follows
5011533A LD1117-3v3 SOT-89 "1A LOW DROPOUT LINEAR REGULATOR 3.3V" Datasheet Crowduino
Another example, the link of datasheet of MOSFET Si2305 is https://www.vishay.com/docs/70833/70833.pdf
Can I use these parts with PCBA services?
Hello @hymd ,
I'm sorry that I couldn't reply to you in time because I didn't receive the notification of your reply.
Since we haven't used the Excel sheet for Elecrow PCBA for a long time, could you please send me this sheet? We will confirm whether the information in this form is correct.
Hello @hymd ,
This Excel sheet was made many years ago, so a lot of the information is out of date.
May I kindly ask are you planning to use PCBA services at elecrow? After you upload your PCB files and BOM to the PCBA quotation page, a project manager will contact you. You can ask them if you have any questions.
The following attachments are the datasheet of the components you asked for.
Thank you for providing the data sheets.
An Excel sheet titled Elecrow PCBA is the source of the list I'm looking at. The cells, for instance, for regulators are as follows: Crowduino's datasheet for the "1A LOW DROPOUT LINEAR REGULATOR 3.3V" 5011533A LD1117-3v3 SOT-89 Nearby Ohio landscaping
The list for the Elecrow Parts Library is closed. Could you send us the link you clicked on so we can check it?
