Datasheets of parts in Elecrow Parts Library
I am looking at the Elecrow Parts Library list for parts selection for PCBA, but some datasheets are out of links.
Where can I get the datasheets for the following four parts?
  1. Power Supply 5011533A LD1117-3v3
  2. MOSFET 4022023A  CJ2305
  3. MOSFET 4030523A  Si2305
  4. Diode 4011554B SS54B
  • Hello @hymd ,
    The Elecrow Parts Library list is closed. Could you send the link you visited for us to check?
  • The list I am looking at is an Excel sheet for Elecrow PCBA.
    For example, for regulators, the cells are as follows
    5011533A LD1117-3v3 SOT-89 "1A LOW DROPOUT LINEAR  REGULATOR 3.3V" Datasheet Crowduino
    Another example, the link of datasheet of MOSFET Si2305 is https://www.vishay.com/docs/70833/70833.pdf
    Can I use these parts with PCBA services?
  • Hello @hymd ,
    I'm sorry that I couldn't reply to you in time because I didn't receive the notification of your reply.
    Since we haven't used the Excel sheet for Elecrow PCBA for a long time, could you please send me this sheet? We will confirm whether the information in this form is correct.
  • Hello @hymd ,
    This Excel sheet was made many years ago, so a lot of the information is out of date.
    May I kindly ask are you planning to use PCBA services at elecrow? After you upload your PCB files and BOM to the PCBA quotation page, a project manager will contact you. You can ask them if you have any questions.
    The following attachments are the datasheet of the components you asked for.
  • Thank you for providing the data sheets.
  • An Excel sheet titled Elecrow PCBA is the source of the list I'm looking at. The cells, for instance, for regulators are as follows: Crowduino's datasheet for the "1A LOW DROPOUT LINEAR REGULATOR 3.3V" 5011533A LD1117-3v3 SOT-89 Nearby Ohio landscaping
    The list for the Elecrow Parts Library is closed. Could you send us the link you clicked on so we can check it?
