Why Thinknode M1 has no GPS signal?
edited September 2025 in ESP32 & Lora
Please try the following.
1 Have you turned on the GPS switch?
2 In addition, the device must be placed outdoors to have a GPS signal. Is the device placed outdoors?
3 Please update your device to the latest firmware (both stable and unstable) and try again. The firmware update link is below.
https://flasher.meshtastic.org/
4 Maybe you have made a mistake in the settings in the app. I suggest you try this: click Restore Factory Settings in the app, and then turn on the GPS switch on the device
5 If the problem still exists, please open the case and check if the antenna is loose or not fastened properly. If so, adjust the antenna and fasten it properly and try again.
«1
  • edited August 2025
    I have the same problem!
    I just received my order of two M1 Thinknodes, and one of the devices is not able to get a GPS lock.
    I tried all the fixes as per above and there is still no GPS lock>
    The GPS switch is on, the node is outdoors, the antenna connection is good, I completed a factory reset and I tried three different firmware, the original> 2.6.5 > 2.7.4 alpha > 2.6.11.6 beta.
    The second node is usually able to get a GPS lock in about 15 minutes with 5 - 7 satellites.
    What else can I do???
    Please help!
    Please help!
    Hi Marvin ,
    Regarding the issue , We have sent you emails . pls check.
    Best regards,
  • One of the meshtastic chat groups I'm part of gave me the fix. . . . B)
    ▪Leave the node turned on until its battery is completely drained.
    ▪Once the battery is depleted, turn off the node using the power switch.
    ▪Fully charge the battery and turn on the node
    ▪Place the node outdoors where it has a good view of the open sky and wait for GPS lock.
    ¤ Ensure the GPS switch is also on.
    I found that when the battery dropped to 10% and the voltage dropped to 3.30 volts the GPS was able get a lock. It may not be necessary to drain the battery completely. To drain the battery more quickly you can force the backlight to stay on for an extended period.
    Good luck! :)
    Good luck! :)
    Dear Marvin,
    Thank you very much for your update and sharing . We appreciate your kindness. It is honor to have customers like you.
    Best regards,
  • edited September 2025
    I finally managed to get GPS working on my ThinkNode M-1.
    Solution:
    1) Meshtastic Software upgrade to 2.7.7 Alpha with UI
    2) In the configuration, set:
    • Config/Position/Receive Pin: 9
    • Config/Position/Receive Pin: 8
    3) Set the GPS switch on the case to ON
    Everything works perfectly for my nods.
    Good luck.
    Solution:
    Good luck.
    Dear Misiekkk ,
    Thank you very much for the sharing . Wish you a nice day !
    Best regards,
  • I am still having an ongoing problem with the GPS on both of my Thinknodes, and I know of other people having the same issues.
    The GPS Module randomly stops working, and I have to completely drain the battery to get the GPS working again. (as mentioned above) . I am seeing this problem while using both Meshtastic & MeshCore
    Also; I can report that the GPS module is not accurate, and sometimes reports my position more than 100 km from my actual location.
    • Is there a better/easier way to reset the GPS module without having to drain the battery fully??
    • Is there a way to make the GPS more accurate?
    Dear Marvin ,
    Best regards,
    Dear Marvin ,
    Thank you for your patience and support towards us .
    Sorry for the inconvenience caused .
    Could you also try the method mentioned by another costomer in the comments of this post?
    See if this method works.
    Thanks !
    Warm regards,
  • edited November 2025
    How can I correct this issue while using MeshCore?
    Is there a way to improve the accuracy?
