What is the difference between CrowPanel Advance 7.0-HMI ESP32 AI Display v1.0 and v1.2
2»
  • @Ricardo_Rico said:
    I have purchased 8 CrowPanel Advance 7“ HMI| ESP32-S3 V 1.2, and the codes for version 1.0 are not working on these screens, version 1.2, black screen, please what is the solution?
    Dear Ricardo_Rico,
    1. Please pay attention to this content : "Currently our course programs are suitable for the old version of hardware. The course programs for the new version of hardware need to be modified according to the factory program, and we will update them later."
    2. Please also refer to other users' comments on this post.
    Thanks!
  • In the end, is there any example code that brings something to the display of an Advanced 7.0 v1.2?
    Even the firmware code has been deleted
    Dear TitiMoby ,
    I just updated the link in my original post, please check it again.
  • I will try. It is quite painful to have a folder with copied libraries out of normal Arduino IDE behaviour.
    Each time I want to switch from CrowPanel to other regular project, I have to set back the sketchbook location
  • Hello,
    The PlatformIO demo from this link: Google Drive folder does not work with the CrowPanel 7" Advance v1.2.
    When using Arduino with ESP-IDF v3.0.2 and replacing the board with ESP32S3_120M, everything works perfectly.
    I’m looking for a working PlatformIO framework configuration for this board.
    Any help or guidance would be appreciated. Thank you!
  • edited July 28
    The CrowPanel Advance 7.0-HMI ESP32 AI Display v1.2 features hardware improvements over v1.0, including better power management, improved touch response, and enhanced compatibility with peripherals, offering more stable performance for embedded and IoT applications using the ESP32 platform..
  • @Algirdas said:
    Hello,
    Dear Algirdas,
    We apologize for the inconvenience caued.
    Did you encounter any errors when using our PlatformIO program? Please copy and send us a screenshot of the error messages for further analysis. And also plesease describe the specific Problem/Fault Phenomenon.
    Best regards,
