ESP32 7inch display V3.0 touch isn't work
If your ESP32 V3.0 touch screen doesn't work,or Lesson 4 touch example code doesn't work,
you can try to use the attached file upload code to make the touch work.
Note that the ESP32 version is 2.0.x, not 3.0+.
The CrowPanel_ESP32_LVGL_Demo attachment contains the main program and gfx_conf.h for Lesson 5.
Please replace the main program and the gfx_conf file, and it should work properly.
If you want to test the code for the later lessons, you can add new content on the basis of this LVGL_DEMO , replace gfx_conf.h in the same way.
Our engineers will update all lesson codes as soon as possible.
Thanks for the update! I'll try using the attached files and replacing the main program and gfx_conf.h as suggested. Looking forward to the updated lesson codes.
This was working for a while but is now broken again - I have confirmed the board version and used all the elecrow provided libraries.
edit - I see a whole bunch of the github was updated a week ago, I'll try the newer files and report back
I had crash problem and I rolled back to ESP32 3.1.3 version.
Thank you for the update. I’ll try using the attached CrowPanel_ESP32_LVGL_Demo and replace the main program and
gfx_conf.h
as suggested. I’ll also make sure to stick with ESP32 version 2.0.x for compatibility. Looking forward to the updated lesson codes—appreciate the support!Troubleshooting issues with a new display can definitely be frustrating. A lot of times, it comes down to a small detail like a library version or a specific setting in the code. It's great that the team has provided updated code to try. My advice would be to double-check that you have the correct board selected and that all the necessary libraries are the most up-to-date versions before trying again.
thanks for the information
