ESP32 7inch display V3.0 touch isn't work
If your ESP32 V3.0 touch screen doesn't work,or Lesson 4 touch example code doesn't work,
you can try to use the attached file upload code to make the touch work.
Note that the ESP32 version is 2.0.x, not 3.0+.
The CrowPanel_ESP32_LVGL_Demo attachment contains the main program and gfx_conf.h for Lesson 5.
Please replace the main program and the gfx_conf file, and it should work properly.
If you want to test the code for the later lessons, you can add new content on the basis of this LVGL_DEMO , replace gfx_conf.h in the same way.
Our engineers will update all lesson codes as soon as possible.
  • Thanks for the update! I'll try using the attached files and replacing the main program and gfx_conf.h as suggested. Looking forward to the updated lesson codes.
  • edited March 25
    This was working for a while but is now broken again - I have confirmed the board version and used all the elecrow provided libraries.
    edit - I see a whole bunch of the github was updated a week ago, I'll try the newer files and report back
  • I had crash problem and I rolled back to ESP32 3.1.3 version.
  • edited 9:36AM
    Thank you for the update. I’ll try using the attached CrowPanel_ESP32_LVGL_Demo and replace the main program and gfx_conf.h as suggested. I’ll also make sure to stick with ESP32 version 2.0.x for compatibility. Looking forward to the updated lesson codes—appreciate the support!
