How to use jumperless 2 / 3?
Is there a power up sequence and power down sequence we must follow for the Junperless to work at all, or work properly without causing issues withe the test circuit that is plugged into the jumperless? Like, turn off test circuit first, then turn off jumperless, or turn on jumperless, then turn on test circuit? Because I don’t want to “hot start” my test circuit, or cause it to fail if improperly shut down.
What is the proper way to power up and power down with a prototype circuit using the Jumperless Jumperboard?
