Cannot upload code because firmware update failed
Hi,
I have just got the Crowbits Inventor Kit delivered and, following the instructions, I connected the MicroBits controller to the PC.
I also installed and started Letscode (V1.1.0 RC3.4), added Crowbits-MicroBit module, and it connected fine.
The driver was recognized automatically, but I installed the driver again from the menu. According to the manual I also selected the Install Firmware menu item because I was connecting it the first time. When it was finished, it said it was successful.
Now, when I try to upload a simple code to display some text onto the controller, I always get the following error message from Letscode exactly as written here: "Install Firmware Fail, Try Again Please!".
In the log output window I see the following messages:
Welcome to Letscode
EPERM: operation not permitted, open 'C:\Program Files (x86)\Letscode\Python37\Scripts\main.py'import m
achine;machine.reset()
MicroPython v1
.13 on 2020-12-21; micr
o:bit v2.0.0-beta.3 with nRF52833
Type "help()" for more inform
ation.
What could be the reason? Didn't I get the latest software for download?
  • Thank you for your use, you can download the latest letscode software.After installation, use administrator privileges to open the software, and then use,can solve this problem.
  • I run mac os, I can install Letscode and the usb drivers but the "firmwire installation" fails everytime.
    No way to get around it.
    Any one has a lead on this ?
    Command failed: /Applications/Letscode.app/Contents/Arduinoapp/Contents/Java/arduino-builder -compile -hardware
