Question about the USB HUB/PowerManager for RPI Zero
https://www.elecrow.com/wiki/index.php?title=USB_Hub%26Powermanager_for_RPI_Zero_v1.0
Will it charge the RPI Zero device if you connect a battery to the board? OR does the battery only power the HUB?
  • You could connect a battery to the USB-HUB, and connect the RPI Zero, then it can charge the RPI Zero.
    It supports two ways to charge, a Battery port for the battery, and a micro USB power port for the USB directly.
  • FUDUI
