What is the lithium battery interface type and input voltage for ESP32 dispalys?
edited November 2024 in ESP32 & Lora
The type of lithium battery port is PH2.0. The input should be DC3.7v~5v.
Please check the attachment for the connector specifications.
👉️Back to FAQ page👈️
  • the maximum charging current is 500mA, so the battery capacity doesn't need to be too big. Theoretically, a 2500mAh battery needs 6 hours of charging.
  • Hi
    Question about the PH2.0 Battery Port
    Can this be used to power from constant 5V DC source? ie, not using a battery, but using an LDO
    Just want to make sure that there is no back-feeding from the charger circuit that might cause an issue
