External Power question.
In the docs it say external power.
Is the external power connector the BAT connector SH 1.0mm ?
Can I attach any kind of 5Volt power to this?
What happens if I same time connect a USBC to the board ? Will it then try to charge over the BAT connector ? It sounds like stuff going to break if I have a external powersource that is not a battery and same time connect USBC ?!
Please let me know how I can safe use external power supply and same time use USBC cable.
  • I got the 5" version V3.0
  • Hello @fableman ,
    Can be connected to 5V at the same time, connecting the battery can also charge the battery
    1. Can the source of power on the BAT connector be a DCDC converter? or must it be a battery (I dont want the screen to charge)
    2. If yes, how do I prevent it from charging ?
    3. And it was ok to have a 5Volt source on the BAT connector same time using the USBC cable for updating the software ?
    4. what type os JST cable do I need for the BAT port 2mm ?
