Lora Basic Gateway Module impossible to init (impossible to connect with esp in wifi)
i received my order of a Lora Basic Gateway Module but i can't init it.
in Wifi i see ssid but when i want to connect with "12345678" password it's not work (phone say me incorrect password) .
in ethernet there is no connection (apparently is disable by default?)
i install libraries and board (in version 2.0.3) for arduino ide and flash with factory system "ESP-sc-gway-end.ino" (flash is all right) but same result impossible to connect (i try with computer and phone)
i think maybe it's power is too low and try with 2.1A power supply but result is the same impossible to connect to wifi
well i solve my problem i change default password in ESP-sc-gway-end.ino .... i am very disappointed why 12345678 password don't work....
Hi Gabiyo,
I assume you change your password by altering and recompiling the code from this website at the bottom under resources:
https://elecrow.com/wiki/lora-basic-gateway-module.html
My question is how did you compile it with no errors. I have spent a lot of time following this link carefully and I get lots of compile errors. I am sure I am doing something wrong but cannot figure out what.
Thank you for your time.
