ESP32 HMI Display in PlatformIO reports an error
PlatformIO reports an error when trying to install a dependency: "Please install Git client from https://git-scm.com/downloads ”. This means that PlatformIO needs to use the git tool to download the dependencies when compiling or uploading code, but git is not installed on the system or the path is not configured correctly.
Resolution
1. Install Git
  • Open the official Git download page.
  • Depending on your operating system (e.g. Windows, macOS, or Linux), download and install Git.
  • During installation, make sure to select "Add Git to PATH ”, which will allow PlatformIO to access Git in the terminal.
2. Verify that Git is available
Once the installation is complete, run the following command in the terminal to ensure that Git is installed correctly:
git --version
If you get output similar to the following, the installation was successful:
git version 2.x.x
3. Rerun the PlatformIO project
  • Go back to VS Code and re-run the PlatformIO tasks (e.g. uploading code).
  • If the previous error was Git-related, it should have been resolved.
Cautions **Configuration of environment variables
  1. **Environmental variable configuration issues
    • If Git is installed but still reports the same error, check that Git has been added to the environment variable PATH correctly:
      • Windows: Right-click “This PC” > Properties > Advanced System Settings > Environment Variables > add the path where Git is installed to Path (e.g. C:\Program Files\Git\bin).
      • macOS/Linux: Make sure that the git command can be run directly from the terminal.
  2. PlatformIO Updates: Make sure the git command can be run directly from the terminal.
    • If the problem persists, try updating the PlatformIO plugin:
      • Open PlatformIO Home in VS Code (left icon).
      • Go to Settings and check for updates.
  3. Network issues
    • If you have a restricted network environment (e.g. a firewall or proxy), git may not be able to download the dependencies correctly, it is recommended to retry with a good network environment.
After completing the above steps, the issue should be resolved. If in doubt, please provide further log information or environment-specific instructions!
