RC050S Fan Connector
I need to replace the fan for my RC050S, but I can't find any information about what the fan size is or anything.
Strictly speaking the fan still works, if I can get the correct size jumper for the board, but again I can't find any information on the fan or what size jumper I would need to reconnect it.
Does anyone have any info or details?
  • edited November 2024
    Hello @Hyperion0
    Here's the fun connector info:
    Connector terminal: 2.54 interface, wire length: 9-10cm, screw hole: for M3 screws, the hole size is just right to fit an M3 screw directly.
    Fun size:25mm* 25mm* 10mm
    2510, 2.5CM 5V hydraulic bearing, 26*17MM with heatsink, micro cooling fan, HY2.0 interface, 2P wire, length 9CM.
  • It sounds like a tricky situation! Have you checked forums or support sites like mykphrconnect? They often have detailed specs and user discussions that could help identify the fan size or correct jumper for your RC050S. Alternatively, reaching out to the manufacturer directly might provide the specific details you need.
