4.3" HMI Tutorial error
Trying to run lesson 3 to display images from sd card, however after requesting compilation I am presented with an error message that says "Compilation error: 'GPIO_NUM_46' was not declared in this scope; did you mean 'GPIO_NUM_6'?"
I have checked sketch and all appears normal ?
Hello @martinbshaw ,
If you downloaded the library through the platform, please note that the version of lvgl library is at 8.3.x, lovyangfx library is at 1.1.8, because the latest version may not be compatible.
As the same time,In the meantime, please note that your configuration is correct
