Lr1302 hat
can it be used in helium?
I have a Nebra miner that works very well with LoRaWLR1302 Module SPI EU868 SX1302 and I also have LR1302 868M/915M LoRaWAN Hat for RPI SX1302 but when I change the Nebra hat for the new LR1302 hat with the LR1302 module, the Helium network does not recognize the module. Can someone help me? Thanks...
Hello @rafael
It should be a wiring mismatch between this Nebra miner of yours and the LR1302 hat, this is our startup pin:
You can check this
Thanks, but it doesn't do anything. What happens is that my operating system is crankk, it's a multi-miner in which I can mine helium, wingbits, etc. and when I open the ssh console, nothing happens when I use those parameters. I'm sorry for my ignorance. Right now I'm using Google Translate since my language is Spanish.
Tengo este error:Error: Config(decode error: keypair uri: could not load ecc keypair in slot 0: Ecc608(Timeout))
We regret that our hardware is only compatible with the Raspberry Pi buster system and not with this miner.
I hope you have a great day!
If you have any further questions, please don't hesitate to let me know.
