Can I connect the power supply and power bank to CrowPi2 at the same time?
Thank you for making such a good product, my son is using it to learn Python.
There are two ways to power the CrowPi2. However, about the hardware, my question is:
Can I use the power supply and power bank to supply power for CrowPi2 at the same time? Will the power supply charge the power bank?
No, you can't. Please don't use any power bank and the DC-12V power port to power the CrowPi2 at the same time. It will damage the power bank battery and may even pose potential safety risks.
Hi Tony,
If the power bank is turned off so it is not supplying power, can it be charged from the CrowPi2's micro-USB port when the CrowPi2 is powered by DC-12V?
No, the power bank will not be charged through the DC12V power port, please do not use them at the same time!
there are power bank with a female input at 12V barrel 5.5 mm, and a switchable male output 12V barrel 5.5 mm.
Can I connect the CrowPi power supply to the power bank input to charge it, and use the power bank output to power the CrowPi via the 12V barrel jack?
My intention is to have a backup supply like all notebooks, than can be always connected to main supply and recharge the battery, but in case of main power failure, the device remain switched on via the battery.
here some links:
ELEOPTION - Batteria per telecamera CCTV senza fili, per monitor bambini, DC-168 DC 12 V 1800 mAh, con spina : Amazon.it: Fai da te
https://www.amazon.it/dc-168-DC-1800-mAh-batteria-fotocamera-Wireless/dp/B07546GMCTele ELEOPTION Batteria ricaricabile ricaricabile agli ioni di litio per batteria CCTV da 12V Capacidad muy alta 6800MAH DC12680 : Amazon.it: Elettronica
https://www.amazon.it/ele-ELEOPTION-Batteria-ricaricabile-Capacidad/dp/B07YSCXGNFMini UPS con batteria interna di grande capacità e uscite 5 V e 12 V, adatto per router, fotocamere, allarmi, ecc. : Amazon.it: Informatica
https://www.amazon.it/batteria-interna-uscite-fotocamere-allarme/dp/B07DPTF9VWGruppo di continuità Mini UPS per WiFi, Router, Modem, Telecamera di Sorveglianza con Batteria 10000mAH Ingresso DC/USB Uscita 5V 2A USB e 5V 9V 12V 2A DC : Amazon.it: Informatica
https://www.amazon.it/gp/product/B07W8MCBMS
