Crowtail- DWM1000 UWB
Hi respected community members.
I am writing on this post with reference to a product I purchased from crowtail ie. DWM1000 UWB for indoor positioning. So let me quickly explain my issue. I am facing trouble in connecting 2 Tags with 4 anchors. So in my room I have fixed the 4UWBs at each corner. When I am using only 1 tag with the 4 anchors I am able to get the reading from each anchors using the SSCOM software as given in the products wiki. BUT!!! If I integrate one more tag in the same environment my previous tag gets disconnected or just stops reading distances from the anchors. And yes I am using seperate laptops running SSCOM software but it doesn't help.
I need to integrate 2 tags with 4 anchors anyone please guide me. I bought 7 UWBs I wanna make sure it works.
I will be glad if I can receive some help from you all.
Thanks
Hello @mollygxng ,
May I kindly ask did you use the AT command
AT+anchor_tag=model,IDto set different ID number for the tags?Parameter description:
Model: 1 is to select anchor mode, 0 is to select tag mode
ID: Set the ID of the anchor and tag, starting from 0
