The samples for the 7" may hve issues. the code in theCrowPanel_ESP32_Tutorial\Code\V3.0\Lesson 2 Draw GUI with LovyanGFX\4.3inch_5inch_7inch\Draw referes to the tft and not the LGFX object as defined in the gfx_conf.h. Thus the constant definition of TFT_BLACK,TFT_BLUE,etc are not defined and the object tft.
tft.begin();
tft.fillScreen(TFT_BLACK);
tft.setTextSize(3);
delay(100);
I am using the PlatformIO demo code.
this demo code incorporated with LVGL8.3.x. When i tried to update the LVGL to 9.x version i was getting multiple error like Compilation error: 'lv_disp_draw_buf_t' does not name a type; did you mean 'lv_draw_buf_t'?. Its due to major changes made in the LVGL 9.X. Can someone help to setup the lvlg9.x?
I noticed that you created a new libraries directory under the Arduino libraries directory. This should not be like this.
![](https://forum.elecrow.com/uploads/editor/x6/dkhbv50698ta.png)
Instead, you should directly put all the libraries (such as lvgl, etc.) under the Arduino libraries directory.
![](https://forum.elecrow.com/uploads/editor/lc/0mhby468211v.png)
Examples from lessons 5, 7 and 8 are loading, but there is nothing on the screen
May I kindly ask which hardware version is your HMI?
ESP32S3 Dev Module
tft.begin();
tft.setTextSize(3);
delay(100);
tft.fillScreen(TFT_BLUE);
delay(1000);
tft.fillScreen(TFT_YELLOW);
delay(1000);
tft.fillScreen(TFT_GREEN);
delay(1000);
tft.fillScreen(TFT_WHITE);
delay(1000);
tft.fillCircle ( 100, 100 , 50, TFT_YELLOW);
tft.setCursor(200, 240);
tft.print("Hello, Elecrow");
@Igor
![](https://forum.elecrow.com/uploads/editor/8d/pn5sw4njwqna.png)
I am also working on the CrowPanel ESP32 HMI 5.0'' Display and able to make display up by using the demo code which i referred in the below link.
https://www.elecrow.com/wiki/esp32-display-502727-intelligent-touch-screen-wi-fi26ble-800480-hmi-display.html#schematic-pcb
