Analog read pin on the 7" display ESP32 board
edited July 2024 in Elecrow HMI Display
Completely new to this display, can someone explain to me how to wire an analog input (0-3 volt)? And is there a simple (demo) sketch for output to the serial monitor?
  • edited July 2024
    Hello @HansTis ,
    To read analog value, you need an ADC pin, but there is no available ADC pin. However, if you don't need to use a speaker, you can use GPIO17 pin as ADC input pin to read analog value.
    Use the following code:
    #define A_pin 17
        void setup()
        setMode(A_pin, INPUT);
        void loop()
        int A_value = 0;
        A_value = digitalRead(A_Pin);
        Serial.println(A_value);
        delay(1000);
  • Thanks for your advice!
