CrowPanel 5" ESP32 Display 800x480 simple code
Can someone share a simple code to change the background color of my display? I can't get the display to respond to anything. This is my simple code if someone helps me correct it.
LovyanGFX library 1.1.16
Code
define LGFX_USE_V1
include <LovyanGFX.hpp>
include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
public:
lgfx::Bus_RGB _bus_instance;
lgfx::Panel_RGB _panel_instance;
lgfx::Light_PWM _light_instance;
LGFX(void)
cfg.panel = &_panel_instance;
  cfg.pin_d0  = GPIO_NUM_8; // B0
  cfg.pin_d1  = GPIO_NUM_3;  // B1
  cfg.pin_d2  = GPIO_NUM_46;  // B2
  cfg.pin_d3  = GPIO_NUM_9;  // B3
  cfg.pin_d4  = GPIO_NUM_1;  // B4
  cfg.pin_d5  = GPIO_NUM_5;  // G0
  cfg.pin_d6  = GPIO_NUM_6;  // G1
  cfg.pin_d7  = GPIO_NUM_7;  // G2
  cfg.pin_d8  = GPIO_NUM_15;  // G3
  cfg.pin_d9  = GPIO_NUM_16; // G4
  cfg.pin_d10 = GPIO_NUM_4;  // G5
  cfg.pin_d11 = GPIO_NUM_45; // R0
  cfg.pin_d12 = GPIO_NUM_48; // R1
  cfg.pin_d14 = GPIO_NUM_21; // R3
  cfg.pin_d15 = GPIO_NUM_14; // R4
  cfg.pin_henable = GPIO_NUM_40;
  cfg.pin_vsync   = GPIO_NUM_41;
  cfg.pin_hsync   = GPIO_NUM_39;
  cfg.pin_pclk    = GPIO_NUM_0;
  cfg.freq_write  = 15000000;
  cfg.hsync_polarity    = 0;
  cfg.hsync_front_porch = 8;
  cfg.hsync_pulse_width = 4;
  cfg.hsync_back_porch  = 43;
  cfg.vsync_polarity    = 0;
  cfg.vsync_front_porch = 8;
  cfg.vsync_pulse_width = 4;
  cfg.vsync_back_porch  = 12;
  cfg.pclk_active_neg   = 1;
  cfg.de_idle_high      = 0;
  cfg.pclk_idle_high    = 0;
  _bus_instance.config(cfg);
  cfg.memory_width  = 800;
  cfg.memory_height = 480;
  cfg.panel_width  = 800;
  cfg.panel_height = 480;
  cfg.offset_x = 0;
  cfg.offset_y = 0;
  _panel_instance.config(cfg);
setPanel(&_panel_instance);
LGFX tft;
void setup() {
tft.begin();
tft.fillScreen(TFT_GREEN); // Cambia el color de fondo a verde
void loop() {
// Aquí puedes agregar tu lógica de bucle
