5" CrowPanel DIS07050H touch input not responsive
I'm having an issue with version 2 of the 5" ESP32-S3 HMI (DIS07050H)
When the device is cold started, touch input is unresponsive. If I press the reset button, after reboot, touch is working correctly. Reset again, and it still works.
If I unplug it for more than 5 seconds, touch is unresponsive again on startup.
I've uploaded identical software to the one V1.1 that I have, and it works fine after both reset and cold start.
I have also tried on multiple units of v2.0, and behavior is consistent on all of them.
I have tried issuing an ESP.restart() is a reset reason is ESP_RST_POWERON, but that doesn't work.
That points to a hardware fault, and I'm guessing that implementing the reset from USB in v2 is causing the issue on cold start. That's not present in v1.1
Any suggestions would be welcome.
  • I should add that in the intended application, the reset button will be inaccessible, so just getting the user to press that after a cold start, apart from being terrible design, is also not practical anyway.
