Compilation error for Home Assistant '7.0-inch_Squareline_Demo.ino'
edited June 2024 in Elecrow HMI Display
Hello
I try to compile the example 7.0-inch_Squareline_Demo.ino for Home Assistant but it fails there:
"C:\\Users\\user\\AppData\\Local\\Temp\\arduino\\sketches\\AA48A0FC2C07221F422079EFB916D276/7.0-inch_Squareline_Demo.ino.elf"
c:/users/user/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-12.2.0_20230208/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: C:\Users\user\AppData\Local\Temp\arduino\sketches\AA48A0FC2C07221F422079EFB916D276\sketch\objs.a(ui.c.o):(.literal.ui_Screen1_screen_init+0x8): undefined reference to `ui_img_small_temp_png'
c:/users/user/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-12.2.0_20230208/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: C:\Users\user\AppData\Local\Temp\arduino\sketches\AA48A0FC2C07221F422079EFB916D276\sketch\objs.a(ui.c.o):(.literal.ui_Screen1_screen_init+0x14): undefined reference to `ui_img_small_hum_png'
c:/users/user/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-12.2.0_20230208/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: C:\Users\user\AppData\Local\Temp\arduino\sketches\AA48A0FC2C07221F422079EFB916D276\sketch\objs.a(ui.c.o):(.literal.ui_Screen1_screen_init+0x1c): undefined reference to `ui_img_small_logo_png'
c:/users/user/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/esp-12.2.0_20230208/bin/../lib/gcc/xtensa-esp32s3-elf/12.2.0/../../../../xtensa-esp32s3-elf/bin/ld.exe: C:\Users\user\AppData\Local\Temp\arduino\sketches\AA48A0FC2C07221F422079EFB916D276\sketch\objs.a(ui.c.o):(.literal.ui_Screen1_screen_init+0x24): undefined reference to `ui_img_small_off_png'
collect2.exe: error: ld returned 1 exit status
Using library Wire at version 2.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\libraries\Wire
Using library SPI at version 2.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\libraries\SPI
Using library WiFi at version 2.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\libraries\WiFi
Using library Networking at version 1.0.0 in folder: C:\Users\user\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0\libraries\Network
Using library AsyncMqttClient at version 0.9.0 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\AsyncMqttClient
Using library AsyncTCP at version 1.1.4 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\AsyncTCP
Using library DHT20 at version 0.3.1 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\DHT20
Using library lvgl at version 8.3.3 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\lvgl-3
Using library GFX Library for Arduino at version 1.4.7 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\GFX_Library_for_Arduino
Using library LovyanGFX at version 1.1.16 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\LovyanGFX
Using library TAMC_GT911 at version 1.0.2 in folder: C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\Arduino_7inch\Arduino_7inch\libraries\libraries\TAMC_GT911
exit status 1
Compilation error: exit status 1
Images are declared here in inch_Squareline_Demo/ui.h#L47
LV_IMG_DECLARE( ui_img_small_temp_png);   // assets\small_temp.png
LV_IMG_DECLARE( ui_img_small_hum_png);   // assets\small_hum.png
LV_IMG_DECLARE( ui_img_small_logo_png);   // assets\small_logo.png
LV_IMG_DECLARE( ui_img_small_off_png);   // assets\small_off.png
These ui_img files are located in the same directory as the ino file:
PS C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\7.0\6、homeassistant\7.0-inch_Squareline_Demo> dir
    Répertoire : C:\Users\user\Documents\Dev\Elecrow_CrowPanel_7.0\7.0\6、homeassistant\7.0-inch_Squareline_Demo
Mode                 LastWriteTime         Length Name
d-----        04/06/2024     23:15                README
-a----        05/06/2024     09:19          12407 7.0-inch_Squareline_Demo.ino
-a----        04/06/2024     23:15            411 debug.cfg
-a----        05/06/2024     09:19            342 debug_custom.json
-a----        04/06/2024     23:15        2715638 esp32s3.svd
-a----        05/06/2024     09:19           1623 README.md
-a----        05/06/2024     09:19           5656 touch.h
-a----        05/06/2024     09:19           7584 ui.c
-a----        05/06/2024     09:19           1460 ui.h
-a----        05/06/2024     09:19            297 ui_events.h
-a----        05/06/2024     09:19           7058 ui_helpers.c
-a----        05/06/2024     09:19           3547 ui_helpers.h
-a----        05/06/2024     09:19         784679 ui_img_elecrow_logo_png.c
-a----        05/06/2024     09:19         226769 ui_img_humidity_png.c
-a----        05/06/2024     09:19         226744 ui_img_off_png.c
-a----        05/06/2024     09:19         226749 ui_img_temp_png.c
Should I move these files to another directory? Could you help me to fix this issue?
Regards
