Connect potentiometers
With a typical ESP32-S3 board such as the one from Seeed, if I want to use pots I just connect them to pins A0, A1, A2, etc.
How do you connect pots to the Elecrow displays such as the CrowPanel 5”?
It doesn’t appear the analog pins are available.
Hello @Mylo ,
We're sorry because the screen is connected to the ESP32 through RGB565 and occupies too many IO ports. There are no extra pins to connect the potentiometer.
If you are not using speakers or SD cards, you may use IO17, IO18, IO10~IO13
Thanks for the information. I’ll take a look.
