7" esp32 s3 won't compile with audio library
My project has BLEdevice, WIFI, ESP32time, preferences and sntp and compiles fine. When I add the audio library you provided in another discussion the compiler stops with an error. The supporting libraries for audio, sd, fs and spi are not compile ok without audio but I include audio I get this error.
Any help would be appreciated.
Bribur
"In file included from C:\Users\Brian\Documents\SynologyDrive\Programming\Arduino\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2.ino:208:
C:\Users\Brian\Documents\SynologyDrive\Programming\Arduino\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2\touch.h: In function 'bool touch_touched()':
C:\Users\Brian\Documents\SynologyDrive\Programming\Arduino\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2\touch.h:166:20: error: reference to 'map' is ambiguous
touch_last_x = map(ts.points[0].x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, lcd.width() - 1);
In file included from c:\users\brian\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\include\c++\8.4.0\map:61,
from C:\Users\Brian\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\BLE\src/BLEDevice.h:14,
from C:\Users\Brian\Documents\SynologyDrive\Programming\Arduino\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2.ino:13:
c:\users\brian\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0\xtensa-esp32s3-elf\include\c++\8.4.0\bits\stl_map.h:100:11: note: candidates are: 'template class std::map'
class map
In file included from C:\Users\Brian\AppData\Local\Temp\arduino\sketches\135AD65BD2B2558CD85C9D0993C84EF0\sketch\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2.ino.cpp:1:
C:\Users\Brian\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\cores\esp32/Arduino.h:153:6: note: 'long int map(long int, long int, long int, long int, long int)'
long map(long, long, long, long, long);
C:\Users\Brian\Documents\SynologyDrive\Programming\Arduino\BLE_client_myUUID_TouchScreen_readValue_wri_TiClk2PrfWifi_Aud2\touch.h:167:20: error: reference to 'map' is ambiguous
touch_last_y = map(ts.points[0].y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, lcd.height() - 1);
class map
