how to configure the tft-esp by drive EK9716BD3 + EK73002ACGB
  • edited April 2024
    Hello @klita
    We recommend to use LovyanGFX library as drive. Please find the following code for the display configuration:
             #include <LovyanGFX.hpp>
            #include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
            #include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
            #define TFT_BL 2
            class LGFX : public lgfx::LGFX_Device {
            public:
              // Instances for the RGB bus and panel.
              lgfx::Bus_RGB     _bus_instance;
              lgfx::Panel_RGB   _panel_instance;
              // Constructor for the LGFX class.
              LGFX(void) {
                // Configure the RGB bus.
                  cfg.panel = &_panel_instance;
                  // Configure data pins.
                  cfg.pin_d0  = GPIO_NUM_15; // B0
                  cfg.pin_d1  = GPIO_NUM_7;  // B1
                  cfg.pin_d2  = GPIO_NUM_6;  // B2
                  cfg.pin_d3  = GPIO_NUM_5;  // B3
                  cfg.pin_d4  = GPIO_NUM_4;  // B4
                  cfg.pin_d5  = GPIO_NUM_9;  // G0
                  cfg.pin_d6  = GPIO_NUM_46; // G1
                  cfg.pin_d7  = GPIO_NUM_3;  // G2
                  cfg.pin_d8  = GPIO_NUM_8;  // G3
                  cfg.pin_d9  = GPIO_NUM_16; // G4
                  cfg.pin_d10 = GPIO_NUM_1;  // G5
                  cfg.pin_d11 = GPIO_NUM_14; // R0
                  cfg.pin_d12 = GPIO_NUM_21; // R1
                  cfg.pin_d14 = GPIO_NUM_48; // R3
                  cfg.pin_d15 = GPIO_NUM_45; // R4
                  // Configure sync and clock pins.
                  cfg.pin_henable = GPIO_NUM_41;
                  cfg.pin_vsync   = GPIO_NUM_40;
                  cfg.pin_hsync   = GPIO_NUM_39;
                  cfg.pin_pclk    = GPIO_NUM_0;
                  cfg.freq_write  = 15000000;
                  // Configure timing parameters for horizontal and vertical sync.
                  cfg.hsync_polarity    = 0;
                  cfg.hsync_front_porch = 40;
                  cfg.hsync_pulse_width = 48;
                  cfg.hsync_back_porch  = 40;
                  cfg.vsync_polarity    = 0;
                  cfg.vsync_front_porch = 1;
                  cfg.vsync_pulse_width = 31;
                  cfg.vsync_back_porch  = 13;
                  // Configure polarity for clock and data transmission.
                  cfg.pclk_active_neg   = 1;
                  cfg.de_idle_high      = 0;
                  cfg.pclk_idle_high    = 0;
                  // Apply configuration to the RGB bus instance.
                  _bus_instance.config(cfg);
                // Configure the panel.
                  cfg.memory_width  = 800;
                  cfg.memory_height = 480;
                  cfg.panel_width   = 800;
                  cfg.panel_height  = 480;
                  cfg.offset_x      = 0;
                  cfg.offset_y      = 0;
                  // Apply configuration to the panel instance.
                  _panel_instance.config(cfg);
                // Set the RGB bus and panel instances.
                setPanel(&_panel_instance);
            LGFX lcd;
  • I compiled and loaded this and nothing displayed.
    I put it all within void setup() { } and a blank
    void loop() { }
    My goal is a basic "shell" or beginning portion that activates the display so I can continue with various programs of my own with it.
    Help appreciated.. regards Bo W4GHV since 1954
  • Hello @W4GHV
    Please try the following demo:
