New 7" Display
Hi
Squareline demo still not working.
https://github.com/Elecrow-RD/esp32-display/tree/master/7.0/3%E3%80%81arduino/7.0-inch_Squareline_Demo
It is working with my old 5" display but not with my new 7" (the new version with I2C port.
Sometimes I can see a faint image on screen 1, screen 2 fading and switching. Touch doesn't work, or you can see the coordinates coming in but nothing else.
Any suggestions?
  • Hello @SM0PYH ,
    Please change the screen driver from Arduino_GFX to LovyanGFX
    and modify
    #include <Arduino_GFX_Library.h>
    #define TFT_BL 2
    #define GFX_BL DF_GFX_BL // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
    /******Please define a corresponding line based on your development board.************/
    //#define Display_43
    //#define Display_50
    #define Display_70
     * Screen Driver Configuration
    #if defined (Display_43)         //4.3INCH 480x272
    Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
      GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
      40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
      45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
      5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
      8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */
    Arduino_RPi_DPI_RGBPanel *lcd = new Arduino_RPi_DPI_RGBPanel(
      bus,
      480 /* width */, 0 /* hsync_polarity */, 8 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 43 /* hsync_back_porch */,
      272 /* height */, 0 /* vsync_polarity */, 8 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 12 /* vsync_back_porch */,
      1 /* pclk_active_neg */, 7000000 /* prefer_speed */, true /* auto_flush */);
    #elif defined (Display_50)         //5.0INCH 800x480
      40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 0 /* PCLK */,
      bus,
      800 /* width */, 0 /* hsync_polarity */, 210 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 43 /* hsync_back_porch */,
      480 /* height */, 0 /* vsync_polarity */, 22 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 12 /* vsync_back_porch */,
      1 /* pclk_active_neg */, 16000000 /* prefer_speed */, true /* auto_flush */);
    #elif defined (Display_70)       //7.0INCH 800x480
      41 /* DE */, 40 /* VSYNC */, 39 /* HSYNC */, 0 /* PCLK */,
      14 /* R0 */, 21 /* R1 */, 47 /* R2 */, 48 /* R3 */, 45 /* R4 */,
      9 /* G0 */, 46 /* G1 */, 3 /* G2 */, 8 /* G3 */, 16 /* G4 */, 1 /* G5 */,
      15 /* B0 */, 7 /* B1 */, 6 /* B2 */, 5 /* B3 */, 4 /* B4 */
      bus,
      800 /* width */, 0 /* hsync_polarity */, 210 /* hsync_front_porch */, 1 /* hsync_pulse_width */, 46 /* hsync_back_porch */,
      480 /* height */, 0 /* vsync_polarity */, 22 /* vsync_front_porch */, 1 /* vsync_pulse_width */, 23 /* vsync_back_porch */,
      0 /* pclk_active_neg */, 16000000 /* prefer_speed */, true /* auto_flush */);
    #endif
     * Screen Driver Configuration  end
    into
    #define LGFX_USE_V1
    #include <LovyanGFX.hpp>
    #include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
    #include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
    #define TFT_BL 2
    public:
      lgfx::Bus_RGB     _bus_instance;
      lgfx::Panel_RGB   _panel_instance;
      LGFX(void)
          cfg.panel = &_panel_instance;
          cfg.pin_d0  = GPIO_NUM_15; // B0
          cfg.pin_d1  = GPIO_NUM_7;  // B1
          cfg.pin_d2  = GPIO_NUM_6;  // B2
          cfg.pin_d3  = GPIO_NUM_5;  // B3
          cfg.pin_d4  = GPIO_NUM_4;  // B4
          cfg.pin_d5  = GPIO_NUM_9;  // G0
          cfg.pin_d6  = GPIO_NUM_46; // G1
          cfg.pin_d7  = GPIO_NUM_3;  // G2
          cfg.pin_d8  = GPIO_NUM_8;  // G3
          cfg.pin_d9  = GPIO_NUM_16; // G4
          cfg.pin_d10 = GPIO_NUM_1;  // G5
          cfg.pin_d11 = GPIO_NUM_14; // R0
          cfg.pin_d12 = GPIO_NUM_21; // R1
          cfg.pin_d14 = GPIO_NUM_48; // R3
          cfg.pin_d15 = GPIO_NUM_45; // R4
          cfg.pin_henable = GPIO_NUM_41;
          cfg.pin_vsync   = GPIO_NUM_40;
          cfg.pin_hsync   = GPIO_NUM_39;
          cfg.pin_pclk    = GPIO_NUM_0;
          cfg.freq_write  = 15000000;
          cfg.hsync_polarity    = 0;
          cfg.hsync_front_porch = 40;
          cfg.hsync_pulse_width = 48;
          cfg.hsync_back_porch  = 40;
          cfg.vsync_polarity    = 0;
          cfg.vsync_front_porch = 1;
          cfg.vsync_pulse_width = 31;
          cfg.vsync_back_porch  = 13;
          cfg.pclk_active_neg   = 1;
          cfg.de_idle_high      = 0;
          cfg.pclk_idle_high    = 0;
          _bus_instance.config(cfg);
          cfg.memory_width  = 800;
          cfg.memory_height = 480;
          cfg.panel_width  = 800;
          cfg.panel_height = 480;
          cfg.offset_x = 0;
          cfg.offset_y = 0;
          _panel_instance.config(cfg);
        setPanel(&_panel_instance);
    LGFX lcd;
       End of Arduino_GFX setting
  • Hi
    Thanks for your answer.
    I could not download the library LovyanGFX.zip
    Broken link i think Best regards
    https://forum.elecrow.com/uploads/122/JY9XJ2Z4TL5W.zip
  • Hey All,
    I have the same issue as SM0PYH (7 inch screen as well), I downloaded the LovyanGFX included in the set of libraries that is on the tutorial page and none of the codes work. Now I get the following error:
    base operand of '->' has non-pointer type 'LGFX'
      lcd->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
    First I used the original code that said Arduino_GFX while the included library only contained an Adafruit_GFX. I sourced Arduino_GFX got the same error as SM0PYH.
    I also tried the last method and failed in the above mentioned way.
    Could someone please please help us out here?
    My Code:
    __________________________________________________________________________________________________________________________________________________________
    #include <Wire.h>
    #include <SPI.h>
    #define LGFX_USE_V1
    #define USE_UI    //if you want to use the ui export from Squareline, please do not annotate this line.
    #if defined USE_UI
    #include <lvgl.h>
    #include "ui.h"
    #endif
    #include <LovyanGFX.h>
    #define TFT_BL 2
    public:
      LGFX(void)
          cfg.offset_x = 0;
          cfg.offset_y = 0;
    LGFX lcd;
       Please config the touch panel in touch.h
    #include "touch.h"
    #ifdef USE_UI
    /* Change to your screen resolution */
    static uint32_t screenWidth;
    static uint32_t screenHeight;
    static lv_color_t disp_draw_buf[800 * 480 / 10];      //5,7inch: lv_color_t disp_draw_buf[800*480/10]            4.3inch: lv_color_t disp_draw_buf[480*272/10]
    //static lv_color_t disp_draw_buf;
    /* Display flushing */
    void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
      uint32_t w = (area->x2 - area->x1 + 1);
      uint32_t h = (area->y2 - area->y1 + 1);
    #if (LV_COLOR_16_SWAP != 0)
      lcd->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
    #else
    #endif
      lv_disp_flush_ready(disp);
    void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
      if (touch_has_signal())
        if (touch_touched())
          /*Set the coordinates*/
          data->point.x = touch_last_x;
          data->point.y = touch_last_y;
          Serial.print( "Data x :" );
          Serial.println( touch_last_x );
          Serial.print( "Data y :" );
          Serial.println( touch_last_y );
        else if (touch_released())
      else
      delay(15);
    #endif
    void setup()
      Serial.begin(9600);
      Serial.println("LVGL Widgets Demo");
    #if defined(Display_50) || defined(Display_70)
      //IO Port Pins
      pinMode(38, OUTPUT);
      digitalWrite(38, LOW);
      pinMode(17, OUTPUT);
      digitalWrite(17, LOW);
      pinMode(18, OUTPUT);
      digitalWrite(18, LOW);
      pinMode(42, OUTPUT);
      digitalWrite(42, LOW);
    #elif defined(Display_43)
      pinMode(20, OUTPUT);
      digitalWrite(20, LOW);
      pinMode(19, OUTPUT);
      digitalWrite(19, LOW);
      pinMode(35, OUTPUT);
      digitalWrite(35, LOW);
      pinMode(0, OUTPUT);//TOUCH-CS
    #endif
      // Init Display
      lcd->begin();
      lcd->fillScreen(BLACK);
      lcd->setTextSize(2);
      delay(200);
    #ifdef USE_UI
      lv_init();
      delay(100);
      touch_init();
      screenWidth = lcd->width();
      screenHeight = lcd->height();
      lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 10);
      //  lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, 480 * 272 / 10);
      /* Initialize the display */
      lv_disp_drv_init(&disp_drv);
      /* Change the following line to your display resolution */
      /* Initialize the (dummy) input device driver */
    #endif
    #ifdef TFT_BL
      pinMode(TFT_BL, OUTPUT);
      digitalWrite(TFT_BL, HIGH);
    #endif
    #ifdef USE_UI
      ui_init();//ui from Squareline or GUI Guider
    #else
      lcd->fillScreen(RED);
      delay(800);
      lcd->fillScreen(BLUE);
      delay(800);
      lcd->fillScreen(YELLOW);
      delay(800);
      lcd->fillScreen(GREEN);
      delay(800);
    #endif
    void loop()
      while(1)
    #ifdef USE_UI
        lv_timer_handler();
        delay(5);
    #endif
    Error message:
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino: In function 'void my_disp_flush(lv_disp_drv_t*, const lv_area_t*, lv_color_t*)':
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:133:6: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino: In function 'void setup()':
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:197:6: error: base operand of '->' has non-pointer type 'LGFX'
      lcd->begin();
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:198:6: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:198:19: error: 'BLACK' was not declared in this scope
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:199:6: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:208:20: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\HughMungus\Documents\Arduino\7inch_display\Demo\Demo.ino:209:21: error: base operand of '->' has non-pointer type 'LGFX'
    exit status 1
    Compilation error: base operand of '->' has non-pointer type 'LGFX'
    Thanks for the help in advanced!
  • Hello,
    Sorry for the broken link. You can install the library by opening the Library Manager in Arduino IDE, and searching for "LovyanGFX". Then click "install".
  • Hi
    Thanks for your effort.
    Using LovyanGFX version 1.1.12
    I got the same error as Hugh_Mungus
    Could you please make a copy of the demofile and make the changes you suggest, compile and publish the code for us.
    https://github.com/Elecrow-RD/esp32-display/blob/master/7.0/3%E3%80%81arduino/7.0-inch_Squareline_Demo/7.0-inch_Squareline_Demo.ino
    //Hans
    Error In file included from C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:98:
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\touch.h: In function 'bool touch_touched()':
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\touch.h:168:74: error: base operand of '->' has non-pointer type 'LGFX'
       touch_last_x = map(ts.points[0].x, TOUCH_MAP_X1, TOUCH_MAP_X2, 0, lcd->width() - 1);
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\touch.h:169:74: error: base operand of '->' has non-pointer type 'LGFX'
       touch_last_y = map(ts.points[0].y, TOUCH_MAP_Y1, TOUCH_MAP_Y2, 0, lcd->height() - 1);
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino: In function 'void my_disp_flush(lv_disp_drv_t*, const lv_area_t*, lv_color_t*)':
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:118:6: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino: In function 'void setup()':
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:170:6: error: base operand of '->' has non-pointer type 'LGFX'
      lcd->begin();
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:171:6: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:171:19: error: 'BLACK' was not declared in this scope
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:172:6: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:181:20: error: base operand of '->' has non-pointer type 'LGFX'
    C:\Users\habr\Desktop\Arduino Projekts\Ny 7 Demo\ESP32_Display_Squareline_Demo\ESP32_Display_Squareline_Demo.ino:182:21: error: base operand of '->' has non-pointer type 'LGFX'
    Multiple libraries were found for "Wire.h"
     Used: C:\Users\habr\Desktop\Arduino Projekts\Libraries\Wire
     Not used: C:\Users\habr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\Wire
    Multiple libraries were found for "SPI.h"
     Used: C:\Users\habr\Desktop\Arduino Projekts\Libraries\SPI
     Not used: C:\Users\habr\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.14\libraries\SPI
    exit status 1
  • Hello,
    The "->" needs to be changed to ".", and the color need to add TFT_
    For example, " lcd->fillScreen(BLACK);" change to  "lcd.fillScreen(TFT_BLACK);"
  • edited March 2024
    Is there an updated 7.0" espif demo? This did not fix my issue. The code compiles and builds but faults and the display reboots.
    Core  0 register dump:
    PC      : 0x42007c75  PS      : 0x00060f30  A0      : 0x82056597  A1      : 0x3fcf3c70
    A2      : 0x3fc9a1c8  A3      : 0x3fcaebd4  A4      : 0x00000001  A5      : 0x00000001
    A6      : 0x02c9a110  A7      : 0x00ffffff  A8      : 0x00000000  A9      : 0x3fcf3c50
    A10     : 0x00000000  A11     : 0x00000001  A12     : 0x42054efc  A13     : 0x0000002c
    A14     : 0x0000002b  A15     : 0x00000000  SAR     : 0x00000010  EXCCAUSE: 0x0000001c
    EXCVADDR: 0x00000012  LBEG    : 0x400570e8  LEND    : 0x400570f3  LCOUNT  : 0x00000000
