The sensor keeps timing out with several different DHT20 libraries. I can see that a device is connected to the I2C port but can’t get any readings out.
hey @Elecrow, with the example code here for example: https://www.elecrow.com/wiki/index.php?title=Crowtail-_DHT20, it keeps logging the temp and humidity with 0 value. I tried with the same library from Github as well and it gives the timeout error. It seemed to be quite a bit newer version that the one downloadable through wiki.
Hello @rewie ,
Could you please send us your code to find the cause of the problem?
Any ideas?
