Raspberry PI 5 suddenly doesn't work
I've been using the Raspberry PI 5 for the past week and it's working fine. But the day it stopped working, the pi didn't work and the power light didn't respond.
  • 1. Check that the adapter that powers it is working properly. Use this adapter to charge your mobile phone or other devices. If it can charge normally, then the adapter is normal;
    2. Make sure the Type-C on the pi5 is intact and not loose;
    3. Use a multimeter to measure whether the power IC next to the Type-C on the pi5 has power supply 3.3V, if not 3.3V, the power IC is not working. If the power IC is not working, the pi5 can not operate normally.
