RPI 3b automatic bightness seting
I have bought Elecrow RC070 7 inch 1024*600 LCD Display with Touch Screen and run it well under RPI 3b. Now I would like to dimm the brightness or even blank the screen if it is not used. But I do not manage it. May you give some advice which settings to set?
Kind regards,
Patrick
  • Hello @Hasso ,
    I'm sorry the RC070 touchscreen can not adjust the backlight brightness by software. You can only turn on/off the backlight through the switch.
    PS. When there's no HDMI signal, the display will leave "No Signal" on the screen for 10 seconds, and the turn off the backlight.
