CrowPi2 "No Signal" Problem
edited December 2024 in Raspberry Pi & CrowPi
Problem:
I purchased the CrowPi2 - All in One Raspberry Pi Laptop & STEM Learning Platform. I am receiving a system error that I am unable to resolve. The error is no signal. I have tried multiple times different suggestions I have read on forums etc. Please advise on next steps. Thanks for your time.
Solution:
1.Check whether the HDMI signal connection is correct and whether the cable and HDMI adapter board are damaged.
2.Check whether it is an SD card problem:
Replace an SD card or burn another system, such as the Raspberry Pi os or CrowPi2 os, and then see if it can start normally.
3. Check whether there is a problem with the Raspberry Pi:
Uninstall the screws, remove the Raspberry Pi, and connect to a screen instead of the CrowPi2 to see if it can boot normally.
  • I have just received my CrowPi1 + Pi4 and have assembled as instructed. At power on, the screen shows No Signal, then Power Saving ZZ, then a blank screen. Not happy. Second issue - does the cordless mouse require a USB transceiver? There was none in the box. I'll test some of the options above later today.
