ESP32 7" + LVGL almost working
I'm running the following code and it almost run. I can compile/upload the firmware, but the problem is: The screen does not work properly.
I've create a squareline project with just a single button and the display does not render it properly.
Packages:
ESP32 v2.0.3
Arduino GFX 1.2.8
LVGL 8.3.11
Any idea how can we make it work?
Thanks in advance.
Code: *************************************************************************************
#include <Wire.h>
#include <SPI.h>
#define USE_UI  //if you want to use the ui export from Squareline, please do not annotate this line.
#if defined USE_UI
#include "lvgl.h"
#include "ui.h"
#endif
#include "Arduino_GFX_Library.h"
#define TFT_BL 2
//#define GFX_BL DF_GFX_BL // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
/******Please define a corresponding line based on your development board.************/
//#define Display_43
//#define Display_50
#define Display_70
 * Screen Driver Configuration
#if defined (Display_43)     //4.3INCH 480x272
Arduino_ESP32RGBPanel* bus = new Arduino_ESP32RGBPanel(
GFX_NOT_DEFINED /* CS */, GFX_NOT_DEFINED /* SCK */, GFX_NOT_DEFINED /* SDA */,
40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 42 /* PCLK */,
45 /* R0 */, 48 /* R1 */, 47 /* R2 */, 21 /* R3 */, 14 /* R4 */,
5 /* G0 */, 6 /* G1 */, 7 /* G2 */, 15 /* G3 */, 16 /* G4 */, 4 /* G5 */,
8 /* B0 */, 3 /* B1 */, 46 /* B2 */, 9 /* B3 */, 1 /* B4 */
Arduino_RPi_DPI_RGBPanel* lcd = new Arduino_RPi_DPI_RGBPanel(
bus,
480 /* width */, 0 /* hsync_polarity */, 8 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 43 /* hsync_back_porch */,
272 /* height */, 0 /* vsync_polarity */, 8 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 12 /* vsync_back_porch */,
1 /* pclk_active_neg */, 7000000 /* prefer_speed */, true /* auto_flush */);
#elif defined (Display_50)     //5.0INCH 800x480
40 /* DE */, 41 /* VSYNC */, 39 /* HSYNC */, 0 /* PCLK */,
bus,
800 /* width */, 0 /* hsync_polarity */, 210 /* hsync_front_porch */, 4 /* hsync_pulse_width */, 43 /* hsync_back_porch */,
480 /* height */, 0 /* vsync_polarity */, 22 /* vsync_front_porch */, 4 /* vsync_pulse_width */, 12 /* vsync_back_porch */,
1 /* pclk_active_neg */, 16000000 /* prefer_speed */, true /* auto_flush */);
#elif defined (Display_70)    //7.0INCH 800x480
41 /* DE */, 40 /* VSYNC */, 39 /* HSYNC */, 0 /* PCLK */,
14 /* R0 */, 21 /* R1 */, 47 /* R2 */, 48 /* R3 */, 45 /* R4 */,
9 /* G0 */, 46 /* G1 */, 3 /* G2 */, 8 /* G3 */, 16 /* G4 */, 1 /* G5 */,
15 /* B0 */, 7 /* B1 */, 6 /* B2 */, 5 /* B3 */, 4 /* B4 */
bus,
800 /* width */, 0 /* hsync_polarity */, 40 /* hsync_front_porch */, 48 /* hsync_pulse_width */, 40 /* hsync_back_porch */,
480 /* height */, 0 /* vsync_polarity */, 13 /* vsync_front_porch */, 1 /* vsync_pulse_width */, 31 /* vsync_back_porch */,
1 /* pclk_active_neg */, 33000000 /* prefer_speed */, true /* auto_flush */);
#endif
 * Screen Driver Configuration end
  Please config the touch panel in touch.h
#include "touch.h"
#ifdef USE_UI
 /* Change to your screen resolution */
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_color_t disp_draw_buf[800 * 480 / 10];  //notice here!!! 5,7inch: lv_color_t disp_draw_buf[800*480/10]      4.3inch: lv_color_t disp_draw_buf[480*272/10]
//static lv_color_t disp_draw_buf;
/* Display flushing */
void my_disp_flush(lv_disp_drv_t* disp, const lv_area_t* area, lv_color_t* color_p)
uint32_t w = (area->x2 - area->x1 + 1);
uint32_t h = (area->y2 - area->y1 + 1);
#if (LV_COLOR_16_SWAP != 0)
lcd->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t*)&color_p->full, w, h);
#else
lcd->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t*)&color_p->full, w, h);
#endif
lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t* indev_driver, lv_indev_data_t* data)
if (touch_has_signal())
if (touch_touched())
/*Set the coordinates*/
data->point.x = touch_last_x;
data->point.y = touch_last_y;
Serial.print("Data (x,y) : ");
Serial.print(touch_last_x);
Serial.print(",");
Serial.println(touch_last_y);
else if (touch_released())
else
delay(15);
#endif
void setup()
Serial.begin(115200);
Serial.println("LVGL Widgets Demo");
#if defined(Display_50) || defined(Display_70)
//IO Port Pins
pinMode(38, OUTPUT); //port_d
digitalWrite(38, LOW);
pinMode(17, OUTPUT); //i2s_sdin
digitalWrite(17, LOW);
pinMode(18, OUTPUT); //i2s_lrclk
digitalWrite(18, LOW);
pinMode(42, OUTPUT); //i2s_bclk
digitalWrite(42, LOW);
#elif defined(Display_43)
pinMode(20, OUTPUT);
digitalWrite(20, LOW);
pinMode(19, OUTPUT);
digitalWrite(19, LOW);
pinMode(35, OUTPUT);
digitalWrite(35, LOW);
pinMode(0, OUTPUT);//TOUCH-CS
#endif
 // Init Display
lcd->begin();
lcd->fillScreen(BLACK);
lcd->setTextSize(2);
delay(200);
#ifdef USE_UI
lv_init();
//delay(100);
touch_init();
screenWidth = lcd->width();
screenHeight = lcd->height();
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 10);
// lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, 480 * 272 / 10);
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Change the following line to your display resolution */
/* Initialize the (dummy) input device driver */
#endif
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
//ledcSetup(1, 300, 8);
//ledcAttachPin(TFT_BL, 1);
//ledcWrite(1, 255); /* Screen brightness can be modified by adjusting this parameter. (0-255) */
#endif
#ifdef USE_UI
ui_init();//ui from Squareline or GUI Guider
#else
//lcd->setCursor(300, 230);
//lcd->printf("Hello World!");
lcd->fillScreen(RED);
delay(800);
lcd->fillScreen(BLUE);
delay(800);
lcd->fillScreen(YELLOW);
delay(800);
lcd->fillScreen(GREEN);
delay(800);
#endif
Serial.println("Setup done");
void loop()
while (1)
#ifdef USE_UI
lv_timer_handler();
delay(5);
#endif
